Solved What Factors Slow Down QCAD
seasdes
Senior Member
Post by seasdes » Sat Sep 17, 2022 1:39 am
I am working on some architectural drawings that I can't share. The file is all 2D. It has 9 Layouts for cover hheet, plans, elevations, sections and images of survey and perspectives. There are many hatches also.
The file size is small.
The file is still workable, just slowing down.
Am I better of placing site plans and images on separate files or is there some other trick.
I really enjoy working with QCAD so am trying to develop a strategy to speed things up.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
seasdes
Senior Member
Re: Solved What Factors Slow Down QCAD
Post by seasdes » Sat Sep 17, 2022 4:56 am
Moderator - Please delete this post as it there are many threads that cover this topic :oops:
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by Husky » Sat Sep 17, 2022 8:30 am
Glad you found the info where you were looking for. :wink:
