[solved] problem with dwg2svg -- "ReferenceError: Can't find variable: fileName"
morsanimi
Post by morsanimi » Mon Sep 05, 2022 8:18 am
Hi everyone,
I am a newbit to QCAD.
I am interested in testing the dwg2svg routine. However, I get an error. I was wondering if I am making a mistake or if there's a bug.
I am using the trial version of QCAD version 3.27.6 on Win10.
I am in the directory Program files/QCAD. There, there is the dwg2svg.bat file and the dwg file that I want to convert.
Then I run the following command.
.\dwg2svg -o out.svg .\infile.DWG
Which gives me the error:
Warning:  RScriptHandlerEcma::eval: script engine exception:  "ReferenceError: Can't find variable: fileName"
Warning:  "<anonymous>() at :scripts/Pro/ImportExport/SvgExporter/SvgExporter.js:125\n<anonymous>(fileName = 'C:/Program Files/QCAD\\out.svg') at :scripts/Pro/ImportExport/SvgExporter/SvgExporter.js:146\nmain() at :scripts\\Pro\\Tools\\Dwg2Svg\\Dwg2Svg.js:174\n<global>() at :scripts\\Pro\\Tools\\Dwg2Svg\\Dwg2Svg.js:304"
Warning:  At least one uncaught exception:
09:13:39: Debug:    "<global>() at 125"
I have noticed that there is no
directory. At the download page I chose to download the Professional trial version.
Could anyone, please, provide some hints, on the error?
Re: problem with dwg2svg -- "ReferenceError: Can't find variable: fileName"
Post by CVH » Mon Sep 05, 2022 8:28 am
C:/Program Files/QCAD/...
is a protected area by the Windows OS.
The tool can't create a file there without special permissions.
Try to output it to a non-protected folder.
Post by CVH » Mon Sep 05, 2022 8:31 am
I have noticed that there is no ...
Correct, most tools are present in compiled form.
morsanimi
Post by morsanimi » Mon Sep 05, 2022 8:51 am
Thank you so much for the very fast and correct answer :D
