Status bar (GS) check mark missing
ouilogique
Post by ouilogique » Sat Sep 03, 2022 1:49 pm
When the status bar is displayed (GS), there is no check mark in the menu.
Configuration
QCAD pro 3.27.6
macOS Monterey 12.5.1
Re: Status bar (GS) check mark missing
Post by CVH » Sat Sep 03, 2022 2:22 pm
I/we have icons upfront and no, non for GS and thus no selection either.
Post by CVH » Sun Sep 04, 2022 6:20 am
Found a bugreport dated 11.07.2016:
https://www.ribbonsoft.com/bugtracker/i ... sk_id=1443
From comparing code it seems the item is not setChecked nor cleared. :wink:
