Problem Selecting a Group - the Logiteck Mouse Catch
GrowMate
Post by GrowMate » Sat Aug 27, 2022 1:44 pm
Recently I found that when selecting a group of elements, the group flashed briefly but failed to stay selected. This happened repeatedly so that I then had to resort to selecting each element individually. After further use even single elements were getting difficult to select.
My first instinct was that QCAD had developed a glitch of some sort and would need to be re-loaded. However it turned out I had fallen victim to the "double-click" syndrome that seems to afflicts all Logitec 'Anywhere' mouse users after a period of time. What happens is that the most-used button on the mouse (i.e., the left one) gets worn and starts to perform a rapid "double-click" by which the first 'selection' click is immediately cancelled by a second click - a mystifying and extremely frustrating problem when it strikes!
There are various 'fixes' for this described on uTube - typically involving replacement of the worn contacts with China-sourced equivalents. However, I opted for a new mouse which arrived the next day and has solved the problem.
I have become so used to the virtues of the 'Anywhere' mouse that I wouldn't consider swapping it for anything else. However this is one of its less attractive features that other Logitech users may want to know about!
Re: Problem Selecting a Group - the Logiteck Mouse Catch
Post by CVH » Wed Oct 11, 2023 8:04 am
frustrating indeed, because if it only fails occasionally you can never be sure whether it is user-related or mouse-button related.
In a blink of the eye your simple to very complex selection is gone ... :shock:
Or replaced by everything connected ... :cry:
The first solution when the button starts to fail is to increase the minimal double-click time.
But ultimately this is not a permanent solution.
I even tried to swap the functions of the buttons because the right button is still preforming well and multiple 'cancel/back' is usually not an issue.
Only the finger habits aren't swapped with the same ease. :lol:
Since using QCAD, I have already 'worn out' 3 (probably too cheap) mice... :lol:
The current one is starting to show the same problem every now and then.
That reminded me of your post. :wink:
