When I try to save a drawing to the Library it says I don't have permission that I need to contact the Administrator, I am the Administrator on my computer.
Computer: Windows 11 Home, Version 21H2
QCAD Version: 3027.6.0
[solved] Issues saving to Library
- Error picture
- Admin error.png (21.99 KiB) Viewed 2269 times
Re: Issues saving to Library
C:\Program Files\QCAD\Libraries\default\Office\ is a windows system path and protected by it for multiple reason. You could change the permission for that folder but I wouldn't recommend it.
Instead I recommend to create a dedicated folder for your library items. Common praxis in windows would be below "Documents". Then tell QCAD below Application Preferences where to find those Library Items:
The big benefit of this setup would be that you don't have to worry about a QCAD update. It will work without any intervention for all upcoming updates ...
Issue solved, thank you.
