Just translation of a message
Ingallpeter
Post by Ingallpeter » Tue Aug 23, 2022 5:22 pm
Hi, it may sound stupid, just a detail.
when exporting in PDF format and it fails the message says "cascó"when it should be "falló".
"Casacar" in Spanish is to break into pieces a brittle thing, especially an egg or a nut in shell.
Regards
Re: Just translation of a message
Post by andrew » Tue Aug 23, 2022 7:05 pm
Thanks. This should be fixed for the next release.
