[solved] dwg2maptiles does not generate all tiles
pechnik
Post by pechnik » Tue Aug 23, 2022 4:24 pm
I have clients who work in Nanocad (https://nanocad.com/). When tiling drawings from this program, it doesn't matter dwg/dxf, some tiles are not generated (see gif file).
It also displays a warning in the console.
dwg2maptiles command:
dwg2maptiles.bat -tile-markers -web-mercator -skip-empty -z 13-18 -b transparent -o E:\temp\tiles_nanocad E:\temp\test_file.dwg
Windows 10, qcad 3.25.2 pro
What could be wrong?
test_file.dwg
(31.41 KiB) Downloaded 187 times
Re: dwg2maptiles does not generate all tiles
Post by CVH » Wed Aug 24, 2022 3:44 am
Not that I have experience with 'maptiles'.
I look at this from the dwg/dxf perspective.
I have difficulties in selecting some entities with some methods.
In special Alt-Select and Box-Select-Intersect with the cursor.
For example when I Box-Select from (17610700,7034100) to (17610200,7034600) it selects only 3 out of 11 polylines.
I then suspect that the -skip-empty option has the same trouble.
First thing that come to my mind are Z values but that doesn't show at first glance.
Still, I can export the details of polylines in full and then it is obvious.
The 8 problematic entities have vertices with Z=1.692347e-10 (6x), Z=1.69237e-10 or Z=1.692365e-10.
Please flatten your drawing with Misc menu .. Modify .. Flatten Drawing to 2D.
There is no image referenced in the test drawing and none was included.
I also spotted a zero length line entity (handle=0x1cd4) at about (17609940,7034104).
Post by Husky » Wed Aug 24, 2022 6:46 am
@pechnik
I'm under the same impression like CVH that the drawing contains tiny pieces of 3D elements.
That would be the GUI tool solution but you can also include the "Flatten Drawing to 2D" function in your CMD command as an option:
dwg2maptiles.bat -flat -tile-markers -web-mercator -skip-empty -z 13-18 -b transparent -o E:\temp\tiles_nanocad E:\temp\test_file.dwg
pechnik
Post by pechnik » Thu Aug 25, 2022 9:50 am
Thanks a lot. -flat option solved the problem!
