I upgraded to mint mate 21 and lost the qcad icon on my dwg files, the files are assosiated with qcad but geniric icon
qcad version 3.27.6.0 (3.27.6
never happend before i can change icon manually but thats not an option for 100+ files
Lost qcad icons on dwg files
- Skärmavbild vid 2022-08-14 12-12-46.png (1.11 MiB) Viewed 2209 times
Re: Lost qcad icons on dwg files
Make sure the MIME type for DWG (and DXF, etc.) files hasn't had its icon changed. I'm not sure how it's done in Mint (or Mate?) but there's usually a MIME type editor that where you can configure such things. If the association is still there and double-clicking a DWG file launches QCAD, that's means probably just the icon got somehow changed. Usually system icons are found under /usr/share (somewhere) but there may be one in the QCAD installation folder.
Len
QCAD Pro
QCAD Pro
