QCAD crashes with Linux Mint 21
BigChinoDon
Post by BigChinoDon » Mon Aug 08, 2022 2:26 am
I upgraded my computer yesterday to the newest version of Linux Mint 21.0. Now when I attempt to open QCAD 3.27.6 Pro I get the splash screen like normal, the screen border appears and then crashes. I've reinstalled QCAD and QT5 normally, but no change. Any suggestions?
Re: QCAD crashes with Linux Mint 21
Post by andrew » Mon Aug 08, 2022 6:45 am
Please reset your configuration:
If you cannot solve the problem, please start QCAD from a terminal and indicate the error message.
Please let us know what exact package (file name of the downloaded file) you have installed.
BigChinoDon
Post by BigChinoDon » Mon Aug 08, 2022 4:10 pm
Thank you Andrew, that worked. Should have thought of that. I tested QCAD on another system that had a new install of Mint 21 and didn't have a problem.
Don
