Mouse cursor offset / not visible
Post by andrew » Mon Jul 18, 2022 1:55 pm
From a QCAD user:
The crosshairs mouse cursor is not at the correct position or the mouse cursor is not visible at all for some functions.
Re: Mouse cursor offset
Post by andrew » Mon Jul 18, 2022 1:56 pm
There is a problem somewhere between Qt (the toolkit QCAD uses) and your system with custom mouse cursors.
You can force QCAD to only use system cursors by enabling the preference:
Edit > Application Preferences > Graphics View > Appearance > Use system cursors
