[solved] Question Marks in Dimension
octavian
Post by octavian » Fri Jul 08, 2022 4:16 pm
Using 3.27.6 with Windows.
I switched a drawing unit from foot to inches to get dimensions in x ' - y ". This works fine for doing an 'info' measure i get 3'-6" which is correct. But when I do dimension/aligned it is displayed as 3?-6?. Thus the ?
Re: Question Marks in Dimension
Post by andrew » Fri Jul 08, 2022 4:26 pm
Perhaps your dimension font does not contain the glyphs for ' and ". If you attach your file, we can help more efficiently, thanks (see also rules above).
octavian
Post by octavian » Fri Jul 08, 2022 4:55 pm
Thanks, I get results when I switched to Arial font. Probably should have mentioned that I am using Windows 7 too.
