Insert library items
olleb61
Post by olleb61 » Mon Jul 04, 2022 12:15 pm
When inpotrting a PDF drawing i get some layers usaly 0 and defpoints, when i add another layer to draw in i Close THE layer one and mark a library items to insert its not visible in THE new layer , i must activate layer 0 to make items visible är there something i miss. Linux Mint 20.3
Re: Insert library items
Post by andrew » Mon Jul 04, 2022 12:20 pm
Each block reference is on a layer (e.g. layer "MyLayer"). Each entity that is part of the block is also on a layer (e.g. layers "0", "MyOtherLayer", etc.). Both the layer of the block reference and the layer of the entity in the block must be visible for an entity to be visible.
If you cannot solve your problem, please do attach your drawing file (see forum rules above).
