Text rotation after editing
rodmaru
Post by rodmaru » Wed Jun 22, 2022 4:03 pm
Hi everyone,
My Qcad started to rotate the text after editing it.
Every time I edit some text, the text is rotated counter clockwise.
Any guess what it is wrong?
Thank you for any help.
Rodrigo
OS: Linux Debian 11
QCAD Professional
Version: 3.27.5.0 (3.27.5)
Internet: QCAD.org
Build Date: May 6 2022
Revision: 28de044
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
rodmaru
Re: Text rotation after editing
Post by rodmaru » Wed Jun 22, 2022 4:09 pm
Answering my own question.
There is a box with the angle in Text geometry.
You need to edit this value with your desired angle.
Thank you.
Post by CVH » Wed Jun 22, 2022 6:05 pm
Very neat that your 7th post is an answer to your own question :wink:
Indeed, most or at least many tool settings are persistent.
Panchdara
Post by Panchdara » Fri Jun 24, 2022 11:13 am
Windows 10
rodmaru
Post by rodmaru » Fri Jul 01, 2022 10:54 pm
CVH, After how many posts an average member can do such a neat post? :D
I did that by accident and took me some time until I find out my own mistake.
Regards
