SVG export issue
juliend
SVG export issue
Post by juliend » Mon Jun 20, 2022 2:49 pm
Hello
The quick SVG export draws the correct shape.
The advanced SVG export with "Preserve Geometry" causes the top arc to flip down.
using qcad-3.27.6-pro-linux-x86_64
test.dxf
(103.71 KiB) Downloaded 223 times
test_quick.svg
(5 KiB) Downloaded 246 times
test_preserve.svg
(3.18 KiB) Downloaded 253 times
Re: SVG export issue
Post by andrew » Mon Jun 20, 2022 3:06 pm
