Good morning.
I have installed Qcad (QCAD Trial for Windows 64bit Installer Version 3.27.6) on Windows 7 64bit professional (service Pack 1).
When I try to open QCAd, it loads all the add-ons and it reaches 100%.
After load all add-on, windows show me the popout with the advise that the program has stopped working and shows me the all white window of QCAD.
how i can resolve the problem?
i must install other program, or extension?
Thanks so much
[Solved] Qcad professional 3.27.6 crash at startup
- blank.jpg (48.77 KiB) Viewed 2072 times
- add-on.jpg (21.68 KiB) Viewed 2072 times
Re: Qcad professional 3.27.6 crash at startuo
Please reset your configuration and try again:
Re: Qcad professional 3.27.6 crash at startup
Very good.
Now is all ok.
Thanks so much
Now is all ok.
Thanks so much
