[solved] Snap to Intersection Not Working
jby601
Post by jby601 » Wed Jun 15, 2022 8:06 pm
OS Linux 5.4.0-117-generic
QCAD 3.27.1
I appear to be unable to snap to the intersection of the circle and the line in the attached file. Any simple reason?
Intersection Query.dxf
(100.95 KiB) Downloaded 193 times
Re: Snap to Intersection Not Working
Post by andrew » Wed Jun 15, 2022 8:10 pm
Line is at Z=8.46
Circle is at Z=0
Misc > Modify > Flatten Drawing to 2D
jby601
Post by jby601 » Wed Jun 15, 2022 8:16 pm
Thank you, Andrew
