[solved] Exiting full screen mode
shelly142
Post by shelly142 » Thu Jun 09, 2022 5:54 pm
The Title Bar has disappeared. The three buttons in the upper right hand corner of the window for minimize, maximize or close have gone away.
Using Windows 7 Pro, software version is QCAD Professional 3.16.5
Re: QCAD Troubleshooting and Problems
Post by andrew » Thu Jun 09, 2022 5:58 pm
To switch on / off full screen mode:
Window > Full Screen
Or F11.
shelly142
Post by shelly142 » Fri Jun 10, 2022 10:21 pm
Bingo, Andrew thank you for your help.
