[solved] ver.3.27.6 Problems Import Files PDF
sergiofrancesco
Post by sergiofrancesco » Tue May 24, 2022 10:10 pm
I believe that the import of "PDF" files is a recent feature of QCAD.
I have been using qcad for less than a year and I don't have a great experience.
I can't import pdf files. Both by invoking CTRL+Shift+I and from File Menu -> Import I am asked to choose the file (and I already agree that the pdf files are not included among those considered importable); However, if I choose a vector pdf file (for example a pdf file generated by a QCAD drawing which is therefore vector), an import error is generated
Qcad Professional
Version: 3.27.6.0 (3.27.6)
Internet: Qcad.org
Compilation date: May 16 2022
Revision: f76bbd6
Qt version: 5.13.2
Architecture: x86_64
Compiler: MSVC ++ 14.0 (2015)
OS Win10
Re: ver.3.27.6 Problems Import Files PDF
Post by Husky » Tue May 24, 2022 10:52 pm
I can confirm this issue. Thanks for reporting it!
Error Message on Win 10/64
Command: import
Error while importing file C:/Users/... test.pdf
Command: open
Opening drawing: C:/Users/... test.pdf
Cannot open file C:/Users/... test.pdf'.
No suitable Importer found. Please check file format and extension.
I'll file a bug report. Bugs like this are usually fixed for the next update. If you need to import pdf's immediately please use a previous QCAD version. Thanks.
Bug report:
https://www.qcad.org/bugtracker/index.p ... sk_id=2369
Post by andrew » Wed May 25, 2022 6:39 am
Please re-download and re-install the 3.27.6 package for Windows 64bit. This was a deployment issue (missing DLL).
Panchdara
Post by Panchdara » Wed May 25, 2022 8:03 am
Purrfect. 👍
Windows 10
