[Solved] Load different font
Richard2952
Post by Richard2952 » Wed May 04, 2022 7:59 pm
Would someone please tell me a step by step instruction on how to load a different font. I have searched online and looked in the Qcad book but to no avail. I wish to use a different font other than the Standard font as the standard font will not allow the special character 'ohm symbol' to be used.
operating system windows 11
qcad version 3.27.3
Re: Load different font
Post by Husky » Wed May 04, 2022 9:09 pm
Is the desired font already on your computer? Will you use it in the drawing for text or dimension? Do you need it for a new drawings or do you need to change font in existing drawings?
Richard2952
Post by Richard2952 » Thu May 05, 2022 10:31 am
I have looked at the font files in the program and there is a number of them....cxf at the end!!! but I do not know how to make use of them.
I have recently upgraded my PC to windows 11 and bought the latest 64 bit qcad program.
I will only be using it for text and not dimensions. With my last version of Qcad (3.24.3.0) using only the Standard text I could use italics and also I could insert the special character 'ohm' symbol. With this latest version I can not insert either.
Previously I saved all my drawings on a hard drive then when I loaded the new 64 bit version I copied the drawings back to the new PC.
I am not so bothered about editing the old drawings but it would be nice to have the facility to insert text and the 'ohm' symbol into any new drawings I produce. For the vast majority of the time I will only use the Standard text so I will need to be able to switch between fonts easily.
Thank you for replying.
Richard
Post by andrew » Thu May 05, 2022 8:38 pm
Using the "Standard" CAD font in italic was never supported in any version of QCAD.
Perhaps, it looked like it if the text was formatted inline, for example "\fStandard|b0|i1|c0|p0;0121". However, this sets the TrueType font to "Standard". Since this TrueType font likely doesn't exist on your system, your system substitutes it with another font, for example Arial or similar:
Screenshot 2022-05-05 at 20.58.11.png (101.35 KiB) Viewed 2788 times
For Ohm, you can copy / paste this symbol which is available in the Standard font (Unicode 0x03A9):
Ω
Alternatively, you can overwrite your Standard.cxf file under fonts with the one attached which provides the same Ω glyph for Unicode 0x03A9 and Unicode 0x2126. This will also be included in future versions of QCAD (>3.27.4).
Standard.cxf
(23.26 KiB) Downloaded 190 times
Richard2952
Post by Richard2952 » Thu May 05, 2022 9:10 pm
Yes it did look like the 0121 in your screen shot. I thought that was italic.!!!
No idea how to overwrite my Standard.cxf file so I will wait for the next qcad upgrade.
Post by Husky » Fri May 06, 2022 1:13 am
Close QCAD, Download the Standard.cxf file from Andrew into your Windows Download folder. Launch the Windows File manager (Windows Explorer) with the shortcut Windows Key + e, navigate to your Download folder, select the mentioned file, copy it with CTRL + C into your clipboard, navigate to the QCAD folder for the fonts - C:\Program Files\qcad-3.27.3-pro-win64\fonts. Insert into this folder the file from the clipboard with CTRL + V. Allow to overwrite the existing file. Restart QCAD. Use the font ... :wink:
