[Solved]Closing Drawing Dialog Box Hangs. Version: 3.27.2.0 (3.27.2)
Re: Closing Drawing Dialog Box Hangs. Version: 3.27.2.0 (3.27.2)
Post by Husky » Thu Apr 28, 2022 7:58 pm
andrew wrote:
Thu Apr 28, 2022 7:03 am
I can reproduce the issue with this file but not with any other.
FYI: I can reproduce the issue with a new inch drawing. I can't reproduce the issue with a new mm drawing ...
If I then test the inch drawing which shows the issue and switch in Drawing Preferences / Unit from inch to mm everything works like a charm.
