[SOLVED] Break out Segment command sometimes doesn't work
pinplate
Post by pinplate » Mon Apr 11, 2022 7:02 pm
I have noticed that in some cases the "Break segment" command does not work, even though it is clear that the line intersects with another line. Instead, the whole line is cut off.
I am using QCAD PRO 3.27.1.0 x64, but I have noticed this with previous versions as well.
Is there any solution to this problem or has anyone else noticed this problem?
Re: Break out Segment command sometimes doesn't work
Post by Husky » Mon Apr 11, 2022 7:47 pm
please attache an example drawing which shows the issue to your post and we will look what is going on. Thanks.
pinplate
Post by pinplate » Mon Apr 11, 2022 8:43 pm
Attached is an example of a file where I cannot break lines with the "break out segment" command.
break_out_segment_problem.dxf
Break Out Segment Problem
(106.45 KiB) Downloaded 191 times
Post by andrew » Mon Apr 11, 2022 8:56 pm
Try:
Misc > Modify > Flatten Drawing to 2D
There are (tiny) Z coordinates in this file (e.g. Z=0.0000000000000089) which makes it every so slightly 3D.
pinplate
Post by pinplate » Mon Apr 11, 2022 9:16 pm
Try:
This solved my problem! Thank you very, very much.
