[not solved ?] Quick Modify Icons
John Hyslop
Post by John Hyslop » Sat Mar 26, 2022 1:52 am
Hi
What is the "Quick Modify" Toolbar Supposed to Show?
All I get is 1 long bar with nothing on it?
See Screenshot / This is The Same in both Linux & Windows Versions..
Cheers
John
Quick Modify.png (85.83 KiB) Viewed 3376 times
QCAD/CAM
Version: 3.27.1.0 (3.27.1)
QCAD.org
Build Date: Dec 13 2021
Revision: 2726424
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
Re: Quick Modify Icons
Post by Husky » Sat Mar 26, 2022 2:25 am
Hi
yes, I can confirm that. It should show the same like the Edit menu. :(
petevick
Post by petevick » Sat Mar 26, 2022 5:55 pm
I can also confirm that the Quick Modify toolbar does not get populated at all.
Pete Vickerstaff
John Hyslop
[solved] Quick Modify Icons
Post by John Hyslop » Sun Mar 27, 2022 10:05 pm
Fixed for next release
Thank you Andrew.
Cheers
John
petevick
Re: [solved] Quick Modify Icons
Post by petevick » Sun May 08, 2022 6:22 pm
Thank you Andrew.
Cheers
John
not fixed in release 3.27.4
Pete Vickerstaff
