(Solved) Block Names
stecoop1
Post by stecoop1 » Mon Feb 28, 2022 9:31 pm
Version 3.26.4.0 (3.26.4)
I've been going a little bit crazy over a problem with block names, but I think I have found the answer/solution. :oops:
The problem I was having is when I insert library objects into a drawing, in the Block List tab, some would be listed by the name I gave them when I created them, but some would be listed as "Block_1, Block_2,...Block_x", making it hard to identify what the block is. :?:
After some careful, though incomplete, testing, I have found that if the filename of the Library object contains a comma (,) or semi-colon (;), the object will appear in the Block List as "Block_x". There may be other characters that cause this behaviour.
Is this a quirk of QCad, a bug, or SOP?
Obviously, I can go through my library files and remove commas and semi-colons from the names, but they do help clarify the name of the object.
Re: Block Names
Post by Husky » Mon Feb 28, 2022 10:18 pm
You didn't mention your OS but most likely "illegal character" are used in the filenames. An example ....
https://www.mtu.edu/umc/services/websit ... ers-avoid/
Maybe you can use a batch filename rename program for that boring task ...
Re: Block Names
Post by CVH » Mon Feb 28, 2022 10:35 pm
stecoop1,
Indeed, comma (,) or semi-colon (;) are not allowed.
These are not allowed for layer names:
smallerThen, greaterThen, slash, backSlash, quotationMarks, doublePoint, semiColon, questionMark, asterix, pipe, comma, equalTo, backtick
Simply tryout to create a new block and typing them returns nothing.
QCAD replaces errors by 'Block_x' where x is one larger looking forward sequentially.
stecoop1
Re: Block Names
Post by stecoop1 » Wed Mar 02, 2022 3:57 am
My operating system is Windows 10 Pro; it permits a lot of special characters in filenames that QCad doesn't allow in block/layer names; a wee bit annoying, but not world ending. BTW, it would take me longer to write the batch file to fix the names than it would take me to fix the couple of dozen filenames by hand.
stecoop1
Re: Block Names
Post by stecoop1 » Wed Mar 02, 2022 4:01 am
stecoop1,
Indeed, I have noticed that QCad limits the use of special characters in block and layer names (ignores them when entered); I just didn't realize it extended to filenames as well. I've been using QCad for over a year and a half, and I'm still learning about it's quirks (special features???).
ryancousins
Re: (Solved) Block Names
Post by ryancousins » Wed Mar 02, 2022 4:16 am
I have no idea if this is the case, but perhaps the limitations on characters is due to the DXF standard that QCAD typically abides by?
Post by CVH » Wed Mar 02, 2022 9:58 am
Not really, only the filename is here the block name ... :wink:
