Duplicate Record Name Problem
Hello
I am a qcad professional user, my qca dworking on my Linux Mint 20.2 Cinnamon. İnformation of my qcad is ;
Sürüm: 3.27.1.0 (3.27.1)
İnternet: QCAD.org
Derleme Tarihi: Dec 13 2021
Düzeltme: 2726424
Qt Sürümü: 5.8.0
Mimari: x86_64
Derleyici: gcc 4.8.1
I have a problem when I run one of my drawing (creating on Autodesk Autocad, *.dwg format and 6,4mb size of 2D architecture drawing) my problem is;
- if I make any changes and try to "save" I got the message of "Duplicate Record name:<objectz< (788955)" and then a Warning message of "/home/.....*.dwg file cannot saved"
- if I try to "save as" option , after I write the file name and then I got same ""Duplicate Record name:<objectz< (788955)" message
NOT: I understand that qcad has a "automatic save" feature and I got tihs "Duplicate...." message qcad's each automatic save trying
İnternet: QCAD.org
Düzeltme: 2726424
Qt Sürümü: 5.8.0
Mimari: x86_64
- Ekran Görüntüsü - 2022-01-20 10-02-11.png (29.02 KiB) Viewed 6376 times
- Ekran Görüntüsü - 2022-01-20 10-00-26.png (26.44 KiB) Viewed 6376 times
Re: Duplicate Record Name Problem
Thanks for sending the DWG file per e-mail. However, the file you sent looks completely different from these screenshots and also does not show that behaviour. Please send the correct file that corresponds to this problem.
sorry but the file I sent to you has also same problem, its why I prefer to sent low size file. :You can see the screenshot below
- Ekran Görüntüsü - 2022-01-21 13-32-58.png (327.06 KiB) Viewed 6312 times
I cannot reproduce the problem here with that file with the exact same package of QCAD.
Here's how I proceed:
- Start QCAD Professional
- Load file
- File > Save
Do you add anything to the drawing in between or modify it in any way?
You could also try the Qt 5.14 package instead which uses a different version of the OpenDesign libraries.
- Load file
- File > Save
I take a screen video. I cant add it in here so I send it as an e-mail. Please check
Thanks. I still cannot reproduce. Did you try the Qt 5.14 package as suggested in the previous post?
Does the problem also happen if you do not add a line before saving?
Sorry for late turn
I run Qcad_qt5.14 version using *.tar.gz than I check it on HELP -- ABOUT menu. Its qt5.14 version. Then I tried to open *.dwg file , try to make some changes and then try to save, but I got same warnin message.
I take shot as a video and send to your info mail just shortly before
Can you please post the contents of your Help > About > System dialog? I suspect that your system locale settings or similar might have something to do with it, as I still cannot reproduce the problem here.
I will try to reproduce the problem with your system settings. If I can reproduce it, I can also fix it. Otherwise, I'm happy to offer you a full refund as QCAD does not seem to work on your system / with your drawings.
Versions
QCAD version: 3.27.1.0
Date: Dec 13 2021
Qt version: 5.14.2
Compiler version: gcc 5.4.0
Build date: Dec 13 2021
Revision: 27264242d55a1145dcd6795a1ed8c653df8887c7
Architecture: x86_64
Device pixel ratio: 1
Configuration file: /home/ykaya/.config/QCAD/QCAD3.conf
OS: Linux
OS version: 20.2
Locale
QCAD locale: tr
Country: 217
Country name: Türkiye
Language: 125
Language name: Türkçe
Script: 7
Script name: Latin
Decimal point: 44
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: UTF-8
Arguments: ./qcad-bin
Plugins
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcaddwg.so
ID=DWG
License=Proprietary
LicenseFile=qcadprolicense|qcadcamlicense
Name=QCAD Professional
PurchaseURL=http://ribbonsoft.com/add-ons/qcadpro-purchase
QtVersion=5.14.2
SystemCodePage=45
Version=3.27.1 (OpenDesign® 22.4.0.0)
Description=Import/export support for the DXF format. Based on dxflib.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcaddxf.so
ID=DXF
License=GPLv2+
Name=DXF
QtVersion=5.14.2
URL=http://www.qcad.org
Version=3.27.1 (dxflib 3.26.4.0)
Description=Integrated help browser.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadhelp.so
ID=HELP
License=Proprietary
QtVersion=5.14.2
URL=http://www.ribbonsoft.com
Version=3.27.1
Description=PDF import.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadpdf.so
ID=PDF
License=Proprietary
LicenseText=This plugin uses PDFium.
Copyright 2014 PDFium Authors. All rights reserved.
* Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
* Neither the name of Google Inc. nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
QtVersion=5.14.2
Version=3.27.1
Description=Polygon clipping, boolean polygon operations, path offset.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadpolygon.so
ID=POLYGON
License=Proprietary
LicenseText=This plugin uses the Boost library.
Boost Software License - Version 1.0 - August 17th, 2003
http://www.boost.org/LICENSE_1_0.txt
Permission is hereby granted, free of charge, to any person or organization obtaining a copy of the software and accompanying documentation covered by this license (the "Software") to use, reproduce, display, distribute, execute, and transmit the Software, and to prepare derivative works of the Software, and to permit third-parties to whom the Software is furnished to do so, all subject to the following:
The copyright notices in the Software and this entire statement, including the above license grant, this restriction and the following disclaimer, must be included in all copies of the Software, in whole or in part, and all derivative works of the Software, unless such copies or derivative works are solely in the form of machine-executable object code generated by a source language processor.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
QtVersion=5.14.2
Version=3.27.1
Description=Map projections.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadproj.so
ID=PROJ
License=Proprietary
LicenseText=This plugin uses the PROJ library.
PROJ uses the MIT license. The software was initially released by the USGS in the public domain. When Frank Warmerdam took over the development of PROJ it was moved under the MIT license. The license is as follows:
Copyright (c) 2000, Frank Warmerdam
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the “Software”), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
QtVersion=5.14.2
Version=3.27.1
Description=QCAD Professional tools.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadproscripts.so
ID=PROTOOLS
License=Proprietary
NameOverride=QCAD Professional
OverridePriority=10
QtVersion=5.14.2
SplashOverride=:/scripts/Pro/splashscreen.png
SplashOverride@2x=:/scripts/Pro/[email protected]
Version=3.27.1
Description=QCAD Scripts.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadscripts.so
ID=SCRIPTS
License=GPLv3
Name=QCAD Scripts
NameOverride=QCAD
OverridePriority=0
QtVersion=5.14.2
URL=http://qcad.org
Version=3.27.1
Description=Spatial Index.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadspatialindexpro.so
ID=SPATIALINDEXPRO
License=Proprietary
LicenseText=This plugin uses the Templated hierarchical spatial trees (THST) library.
MIT License
Copyright (c) 2017 tuxalin
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
QtVersion=5.14.2
Version=3.27.1
Description=Polygon triangulation.
FileName=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64/plugins/libqcadtriangulation.so
ID=TRIANGULATION
License=Proprietary
LicenseText=This plugin uses the Poly2Tri library.
Poly2Tri Copyright (c) 2009-2010, Poly2Tri Contributors
http://code.google.com/p/poly2tri/
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
* Neither the name of Poly2Tri nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
QtVersion=5.14.2
Version=3.27.1
Environment
COLORTERM=truecolor
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
DEFAULTS_PATH=/usr/share/gconf/cinnamon.default.path
DESKTOP_SESSION=cinnamon
DISPLAY=:0
GDMSESSION=cinnamon
GDM_LANG=tr
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/622e08b8_a52c_49cd_a569_6658183cb14f
GNOME_TERMINAL_SERVICE=:1.3351
GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
GTK3_MODULES=xapp-gtk3-module
GTK_MODULES=gail:atk-bridge
GTK_OVERLAY_SCROLLING=1
HOME=/home/ykaya
INSIDE_NEMO_PYTHON=
LANG=tr_TR.UTF-8
LANGUAGE=tr
LD_LIBRARY_PATH=.
LESSCLOSE=/usr/bin/lesspipe %s %s
LESSOPEN=| /usr/bin/lesspipe %s
LOGNAME=ykaya
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
MANDATORY_PATH=/usr/share/gconf/cinnamon.mandatory.path
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
PROJ_LIB=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64
PWD=/home/ykaya/İndirilenler/qcad-3.27.1-pro-linux-qt5.14-x86_64
QT_ACCESSIBILITY=1
QT_AUTO_SCREEN_SCALE_FACTOR=1
QT_QPA_PLATFORMTHEME=qt5ct
SESSION_MANAGER=local/WS-LIN-25:@/tmp/.ICE-unix/1073,unix/WS-LIN-25:/tmp/.ICE-unix/1073
SHELL=/bin/bash
SHLVL=2
SSH_AGENT_PID=1147
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
TERM=xterm-256color
UNICODEMAP_JP=cp932
USER=ykaya
VTE_VERSION=6003
XAUTHORITY=/home/ykaya/.Xauthority
XDG_CONFIG_DIRS=/etc/xdg/xdg-cinnamon:/etc/xdg
XDG_CURRENT_DESKTOP=X-Cinnamon
XDG_DATA_DIRS=/usr/share/cinnamon:/usr/share/gnome:/home/ykaya/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/ykaya
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
XDG_SESSION_CLASS=user
XDG_SESSION_DESKTOP=cinnamon
XDG_SESSION_ID=c2
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
XDG_SESSION_TYPE=x11
XDG_VTNR=7
_=./qcad-bin
Date: Dec 13 2021
Qt version: 5.14.2
OS: Linux
OS version: 20.2
Locale
QCAD locale: tr
Country: 217
Language: 125
Script: 7
Script name: Latin
Decimal point: 44
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: UTF-8
Plugins
ID=DWG
License=Proprietary
QtVersion=5.14.2
SystemCodePage=45
ID=DXF
License=GPLv2+
Name=DXF
QtVersion=5.14.2
ID=HELP
License=Proprietary
QtVersion=5.14.2
Version=3.27.1
ID=PDF
License=Proprietary
QtVersion=5.14.2
Version=3.27.1
ID=POLYGON
License=Proprietary
QtVersion=5.14.2
Version=3.27.1
ID=PROJ
License=Proprietary
QtVersion=5.14.2
Version=3.27.1
ID=PROTOOLS
License=Proprietary
OverridePriority=10
QtVersion=5.14.2
Version=3.27.1
ID=SCRIPTS
License=GPLv3
Name=QCAD Scripts
NameOverride=QCAD
OverridePriority=0
QtVersion=5.14.2
URL=http://qcad.org
Version=3.27.1
ID=SPATIALINDEXPRO
License=Proprietary
MIT License
QtVersion=5.14.2
Version=3.27.1
ID=TRIANGULATION
License=Proprietary
QtVersion=5.14.2
Version=3.27.1
Environment
COLORTERM=truecolor
DISPLAY=:0
GDMSESSION=cinnamon
GDM_LANG=tr
HOME=/home/ykaya
INSIDE_NEMO_PYTHON=
LANG=tr_TR.UTF-8
LANGUAGE=tr
LD_LIBRARY_PATH=.
LOGNAME=ykaya
QT_ACCESSIBILITY=1
SHELL=/bin/bash
SHLVL=2
SSH_AGENT_PID=1147
TERM=xterm-256color
UNICODEMAP_JP=cp932
USER=ykaya
VTE_VERSION=6003
XDG_SEAT=seat0
XDG_SESSION_ID=c2
XDG_VTNR=7
_=./qcad-bin
Unfortunately, I still cannot reproduce the problem.
Can you try to copy / paste the drawing into a new, empty drawing and save that?
Thank
I did and take a video, already sent by mail, please check .
But the result is same.
This time I try to run qcad through .tar.gz version on Terminal screen. I got some warnings on runnig qcad, maybe can help to understand the problem
Hello
I told this problem to my IT manager. Seems he found something about why this problem happened. I take a video and sent to you as mail
In this video you gonna see that I opened the LAYER LIST and there is a "thefris " named layer. If I DELETE this layer, problem fixed.
Interesting, thanks.
I think it's a name collision between layers
TEFRIS
and
tefrıs
Somehow this is considered the same name on your system / locale. Here it is not.
Can you try to rename the layer instead of deleting it (say to TEFRIS2)?
TEFRIS
and
tefrıs
Thank you
Seems its working. In qcad I can not create 2 layers in same name but seems if drawing include same layet name even uppercase/lowercase difference, qcad opened but has this problem.
