QCAD spec:
- version: 3.26.4
- platfom: macos 11.6BigSur NOT M1 chip
How to reproduce my problem.
1) click to command line box to activate the writing commands
2) write "li" hit enter, you should activate line tools by command line
3) write "sx" hit enter you should activate tool to insert coordinates
4) command line ask me for first point, I put coordinates to command line "200,100" (format was check in settings and format should be right) hit enter
Now begin the problem
5) when I hit enter it draw the point but not the point which I've specified in command line but the point which was setup in options boxes (boxes above the draw next to green tick) sometimes ago. Strange is that command seems that received the point from CL because predefined text has changed from "First point" to "Next point"
Am I doing something wrong or it is a bug ?
Thanks for help.
