QCAD Crashes on block insert if layer in block is missing from drawing
shakiestnerd
Post by shakiestnerd » Mon Oct 25, 2021 2:04 am
I've been playing around with creating my own blocks in QCAD.
Usually, my blocks are created with all the elements on layer 0. I wanted to create some blocks with attributes to make changing the text easy. I placed those attributes on a layer named TEXT.
If my drawing contains a layer named TEXT, then the block inserts perfectly. If the drawing lacks a TEXT layer, then QCAD crashes out when I try to insert the block.
I don't consider this a big problem, but it has annoyed me a couple of times. It would be good if QCAD would:
  • Warn me that a block contains a layer that doesn't exist in my drawing and refuse to insert it (instead of crashing)
  • Or just automatically create the layer for me.
  • Or some other friendly behavior
Of course, I could just be doing something wrong. :? That's always a strong possibility.
QCAD 3.26.2 on Linux Mint 20.2
Re: QCAD Crashes on block insert if layer in block is missing from drawing
Post by andrew » Mon Oct 25, 2021 6:48 am
Please attach the DXF file for the block you are inserting and the file you are inserting to, thanks.
Post by CVH » Mon Oct 25, 2021 6:54 am
How can a block definition exists without the layer(s) of one or more of its entities?
In this case Attribute entities on layer 'TEXT'.
Are you referring to 'Block Insert (BI)' or do you refer to 'Insert library Item' ...?
