Array block toolbar button
cpgunn
Post by cpgunn » Thu Sep 09, 2021 3:45 pm
I'm sure I have gone crazy. Using V3.26.4.0. My array of block toolbar button is missing and I can't seem to find it in any of the menus. Sorry for the basic question, but spent a half hour trying different tool bars before I though I would post.
Thanks!
C
Re: Array block toolbar button
Post by andrew » Thu Sep 09, 2021 3:49 pm
Are you inserting a block from the block list or are you trying to turn an inserted block into a block array?
Can you attach a screenshot? Thanks.
Post by CVH » Thu Sep 09, 2021 4:15 pm
If you mean this by 'My array of block toolbar button':
Then set Menu .. View .. Widgets and Toolbars .. Toolbars .. Block to checked
Else you might try to reset your configuration ...
