Hi everybody,
I use QCAD for version v3.26.4x32 and v3.24.3x32 for windows 10 x64.
v3.24.3 is OK,but v3.26.4 have big tool bar and drawing area,
Do anybody know how to solve this problem for v3.26.4
Picture1,it is v3.26.4 (Tool bar icon is big and drawing area resolution is lower.)
Picture2,it is v3.24.3 (Tool bar icon is normal and drawing area resolution is higher.)
Thanks.
QCAD v3.26.4 resolution is normal(big tool bar and drawing area)?
- It is v3.26.4 (Tool bar icon is big and drawing area resolution is lower.)
- 3.26.4.png (231.39 KiB) Viewed 4306 times
- It is v3.24.3 (Tool bar icon is normal and drawing area resolution is higher.)
- 3.24.3.png (200.68 KiB) Viewed 4306 times
Re: QCAD v3.26.4 resolution is normal(big tool bar)?
While entering a topic or replying you might find two tabs under the textbox.
Options and Attachments.
The second tab allows you to include several file types.
Thanks a lot. I get it.
Re: QCAD v3.26.4 resolution is normal(big tool bar and drawing area)?
I found the solution as follows.
General / User Interface / .....
It can work well.
It can work well.
- 3.26.4(OK).png (187.66 KiB) Viewed 4296 times
I would not mind the 'drawing area resolution' as that is just an initial zoom state.
Recently Andrew adviced to reset the configuration with similar issues:
Maybe that helps here too ....
Hi, I would try "Application preferences" - Widgets - CAD Toolbar - Icon size ( I set this to 24 on a 1920/1200 screen ).
Regards.
Regards.
