tried to set some text... I needed a 0.1 font size
AND I noticed that if I delete the font size in the Dialog, just after pressing the backspace the program locks... and crash
Are you experiencing such a behavior on other platform ?
Versione: 3.26.4.0 (3.26.4)
Internet: QCAD.org
Data Compilazione: Jun 4 2021
Revisione: 0bb4334
Versione Qt: 5.14.2
Architettura:x86_64
Compilatore: gcc 5.4.0
Qcad CRASH deleting text font size on Dialog
- Active Member
- output.gif (223.91 KiB) Viewed 4782 times
Re: Qcad CRASH deleting text font size on Dialog
Please let us know what exact platform you are on (Linux distribution and version thereof), thanks.
- Active Member
giuliano@hotbird13:~$ uname -a
Linux hotbird13 5.11.0-25-generic #27~20.04.1-Ubuntu SMP Tue Jul 13 17:41:23 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
giuliano@hotbird13:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
giuliano@hotbird13:~$ cat /usr/share/gnome/gnome-version.xml
<?xml version="1.0"?>
<gnome-version>
<platform>3</platform>
<minor>36</minor>
<micro>8</micro>
<distributor>Ubuntu</distributor>
<!--<date></date>-->
</gnome-version>
giuliano@hotbird13:~/opt/qcad-3.26.4-pro-linux-qt5.14-x86_64$ ./qcad
QCAD version 3.26.4
Warning: Cannot load translation: "assistant_it"
01:37:36: Debug: CadToolBar.initStyle
01:37:36: Debug: EcmaScriptShell.initStyle:
01:37:37: Debug: OptionsToolBar.initStyle
01:37:37: Debug: checking for QCAD Pro updates...
01:37:37: Debug: no updates available
01:37:38: Debug: updateViewport
Warning: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
PS
[ is there a verbose flag to give you more info ?? ]
Release: 20.04
Codename: focal
<gnome-version>
<minor>36</minor>
<micro>8</micro>
</gnome-version>
QCAD version 3.26.4
PS
Win7 pro WinInstaller
QCAD Professional
Version: 3.26.4.5 (3.26.4.5)
Internet: QCAD.org
Build Date: Jul 20 2021
Revision: e596276
Qt Version: 5.13.2
Architecture: i386
Compiler: Unknown
When I clear the Height RMathLineEdit field with backspace I simply get a tooltip saying:
QCAD Professional
Internet: QCAD.org
Revision: e596276
Qt Version: 5.13.2
Architecture: i386
Compiler: Unknown
- Text Height in Drawing Units
Expresion is empty
I cannot reproduce a crash with the same package under Ubuntu 20. However, I do notice a considerable lag when clearing the height input (maybe 10 sec). Please confirm if it crashes there or if there is a delay, perhaps wait for 30 sec.
In any case, the delay seems to stem from a Linux internal thing but can be avoided on the QCAD side. This will be fixed for the next release.
