library item crashes QCAD
J-J
Moderator
Post by J-J » Sat Aug 07, 2021 9:30 am
I found a weird one last night:
In the library I have a collection of bearings, mostly simplified views of files downloaded from the manufacturer's site? I picked a 6300 to insert in my drawing, the preview would not show and then it crashed the program!
I then browsed to the library folder and to open the dxf directly, everything worked ok. I re-saved the drawing in the library folder and tried the insertion again, same problem. Same thing happened when I tried on the laptop. Both machines are on Win7 pro, with the latest release of QCAD
On the main machine,I dumped the dxf and recreated it in the end.
I attached the copy that remained on the laptop if anyone wants to investigate...
6300.dxf
(169.45 KiB) Downloaded 292 times
JJ Win7 pro-64
Re: library item crashes QCAD
Post by CVH » Sat Aug 07, 2021 1:00 pm
Maybe related to FS#2259 given the 149 Attribute Definitions
I have no issues running version 3.26.4.5. on Win7pro
Created a library item (BT) of your file, saved the dxf under the common library folder.
On inserting the item in a new file I get all the details of a 6300 skf listed.
Included the file itself under the common library folder.
Works just the same.
J-J
Moderator
Post by J-J » Sat Aug 07, 2021 7:23 pm
Hi CVH,
Have you tried copying my dxf directly in the library folder instead of creating a new one?
JJ Win7 pro-64
Post by CVH » Sat Aug 07, 2021 8:15 pm
Hi CVH,
Yes, both methods work ...
Post by Husky » Sat Aug 07, 2021 8:55 pm
Hi J-J,
that file has 149 Attribute definitions on frozen layer AM_6. That doesn't looks right to me ...
