Dimensions not scaling along with Viewport
Circle
Post by Circle » Fri Jul 23, 2021 4:59 pm
Drawing scale: 1 to 1
Viewport Scale is: 1:24
In the layout mode, I dimension and the Linear Factor for the dimension is 12.
In the Preferences I have Size Scale Factor set to 1
What setting am I missing?
thanks
Mac: Big Sur version 11.4
QCAD Pro
Re: Dimensions not scaling along with Viewport
Post by Husky » Fri Jul 23, 2021 7:34 pm
So far I can't reproduce the issue. Please attach the dxf for further investigation. Thanks.
Circle
Post by Circle » Fri Jul 23, 2021 7:55 pm
Thanks for taking a look.
2021-07-23 Bathroom Elevation.dxf
(158.12 KiB) Downloaded 329 times
QCAD Pro
Post by Husky » Fri Jul 23, 2021 9:46 pm
Thanks for the drawing.
I can reproduce the issue but I'm not sure what is going on. It looks to me that there is a rounding problem in QCAD.
Fact is: If I take a Viewport with a scale of 1/24 the produced viewport in Paper_Space has an actual scale of 1/23.27272727 or as the Property Editor will show it as 11/256" ... where the " is already a funny thing. Taking then a dim in Paper_Space works only with a manual scale factor (1/24 etc) - the Auto option fails!
@Andrew
Could you please have a look at this issue? Thanks!
Post by andrew » Fri Jul 23, 2021 9:54 pm
I think this is just a duplicate post from the same issue:
viewtopic.php?f=55&t=8615
Circle
Post by Circle » Fri Jul 23, 2021 10:03 pm
Thanks Husky and Andrew for taking a look at this problem.
Is this a problem that I may have created in my newbie approach? Or is it a problem with QCAD?
QCAD Pro
Post by andrew » Fri Jul 23, 2021 10:16 pm
Circle: is this the same problem as described here:
Or a different problem? If so, can you please elaborate?
Circle
Post by Circle » Sat Jul 24, 2021 12:09 pm
Good question Andrew. Yes, it is related - problem goes back to the Linear Factor.
As long as I enter in the right number in the Linear Factor - then all is okay. For now the Linear Factor seems to use 1:12 as the standard.
Thank you both for your help!
QCAD Pro
