Why Do My Blocks Explode When Inserting
seasdes
Senior Member
Post by seasdes » Wed Jul 14, 2021 11:00 am
I am having issues whereby blocks are exploded to individual; entities when I insert them.
It happens with any block and any of the block insertion methods. If insert a block say using the file explorer I may find that the block is exploded when inserted. However if I use the block list it may be inserted as a block. There is no consistency in terms of whether it is imported as a block or not.
Is there a setting that may cause this behaviour?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Why Do My Blocks Explode When Inserting
Post by andrew » Wed Jul 14, 2021 12:30 pm
Please check your preference:
Edit > Application Preferences > Graphics View > Behaviour > Edit block reference in-place
If the option is ticked, it could be that you have a habit of editing blocks inline and then saving the file without closing the block that is being edited, leaving it exploded. This is just a wild guess.
To look into your problem, I'd need your drawing file and the file of the drawing you are trying to insert as block.
seasdes
Senior Member
Post by seasdes » Wed Jul 14, 2021 12:34 pm
Thanks Andrew
Your suggestion may have been the cause.
I will keep an eye on it.
seasdes
QCAD Pro V3.27.8
User since 2021
W10
