Windows 10 / Huawei Mate Book Pro 2020 / Qcad ver 3.26.4.0
I frequently superimpose chimney designs over architects' drawings supplied as jpgs. This works fine with an old laptop I have with a 1920 x 1080 screen resolution. However I recently bought a Huawei Mate Book Pro 2020 with a high res 3000 x 2000 screen and am encountering what appear to be a resolution / layer conflict.
Basically, whenever my cursor is over the jpg, anything I draw disappears behind it and the Bring to Front / Send to Back tool doesn't work.
The "fix" I have discovered is to fade the jpg down to about 80 which makes my drawing visible but unfortunately also causes the jpg to flicker in a rather distracting manner.
I have read several accounts of cad software struggling with 4k screens, so my Huawei was probably not a sensible buy! However it would be useful to know if this particular issue can be fixed since I am delighted with the way everything else works.
I attach a file I am working on together with its jpg. Screen-shots available also if they would help.
[solved] Raster Images & High Res Screen
- 2021-07-02_120854.jpg (242.84 KiB) Viewed 3582 times
- Elliott ACHNACREE.dwg
- (913.44 KiB) Downloaded 284 times
- bambuko
- Senior Member
Re: Raster Images & High Res Screen
This has worked for me (i.e. lock the image layer):
https://qcad.org/rsforum/viewtopic.php?f=33&t=8571
QCad Pro
Linux MX-21.3 "Wildflower"
Re: Raster Images & High Res Screen SOLVED
Incredible! A swift response within minutes that has completely solved my problem!
Sincere thanks.
Sincere thanks.
