could not show some layer objects, but Autocad trueviewer can ?
cyhkimo
Post by cyhkimo » Thu Jul 01, 2021 8:14 am
Re: could not show some layer objects, but Autocad trueviewer can ?
Post by andrew » Thu Jul 01, 2021 8:18 am
Thanks for your report.
Please be much more specific when describing your problem.
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
