Warning: RHatchData::getPainterPaths: hatch pattern too dense
turtle
Post by turtle » Thu Jun 17, 2021 8:57 pm
Greetings all,
I am currently running:
Version:
3.26.2.0 (3.26.2)
Internet:
QCAD.org
Build Date:
Apr 13 2021
Revision:
57092ea
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
On Gentoo Linux,
I have 16 gigs of ram, on a recent laptop.
free -h
               total        used        free      shared  buff/cache   available
Mem:            15Gi       2.2Gi        11Gi       169Mi       2.2Gi        12Gi
And opening large drawings its is very sluggish and hardly usable.
In previous versions this was not the case.
The Format is R18 (2004) DWG Drawing (OpenDesign) (*.dwg)
My console is filling with:
However these files worked fine in older versions.
Please advise
Thank you
Comments based on Version: 3.26.2 unless otherwise noted.
Re: Warning: RHatchData::getPainterPaths: hatch pattern too dense
Post by andrew » Fri Jun 18, 2021 7:06 am
Please attach or provide the drawing file, thanks.
