I am trying to use the measuring tool, but instead of having measurement numbers I have # and a couple of circles? I am using windows 10 QCAD Ver# 3.26.4.0. Any help would be appreciated.
[solved] Symbols instead of numbers?
- Drawing for firewall.dxf
- (103.07 KiB) Downloaded 268 times
Re: Symbols instead of numbers?
Menu / Edit / Drawing Preferences:
Your actual drawing has no font for the measurements. Please change the Dimension Label Font to Standard or which ever font you like to use for dimensioning.
Thank you! That fixed the issue.
