High ASCII characters changing after restart
marek.jansa
Post by marek.jansa » Tue Jun 01, 2021 8:24 am
Dear Andrew,
I have this issue with the Eastern Europe characters encoding in QCad. Can you help me solving it, please?
I describe my drawings in Czech. We use Latin-2 / Windows-1250 / ISO-8859-2 ASCII table.
When I enter high ASCII characters save the drawing and restart QCad, the characters are then shown in their Latin-1 (ISO-8859-1) representation.
An example:
I write ŘEZ BOČ.
Č and Ř are typical Czech characters.
They do not exist in the Latin-1 ASCII table.
In the Latin-2 ASCII table, their position is:
"Č" - HEX C8 (Unicode point = 010C)
"Ř" - HEX D8 (Unicode point = 0158)
When I reopen the drawing, my text "ŘEZ BOČNÍ" is replaced with "ØEZ BOÈNÍ".
In Latin-1 ASCII table:
È - HEX C8 (Unicode point = 00C8)
Ø - HEX D8 (Unicode point = 00D8)
You can see that the ASCII HEX points are the same, Unicode points are obviously different.
What can I do to save my text in drawings in Unicode or to keep QCad from switching to Latin-1, please?
I use:
QCad Professional 3.26.2.0 (3.26.2), 64-bit
Windows 10 64-bit
R27 DXF format
Sources:
https://en.wikipedia.org/wiki/ISO/IEC_8859-2
https://en.wikipedia.org/wiki/ISO/IEC_8859-1
QCad Professional 3.25.2.0 / Windows 10 x64
Re: High ASCII characters changing after restart
Post by andrew » Tue Jun 01, 2021 8:32 am
Please attach your drawing file, so we check if the problem still exists in 3.26.3, thanks.
btjacker
Post by btjacker » Thu Jun 03, 2021 7:37 am
Facing the same issue with Czech " ěř " chars, dxf can by found in this post
Tried on WIndows 8, Windows 10 qcad-3.26.3-pro-win64-installer.msi
Currently working with qcad-3.22.0.5-pro-win64-installer.msi which is OK.
Post by andrew » Fri Jun 04, 2021 9:17 am
This should be fixed in QCAD 3.26.4 which is now available from your download link.
marek.jansa
Post by marek.jansa » Sat Jun 19, 2021 9:09 am
Dear Andrew,
sorry for a late reply, I did not receive notifications for this thread (I thought I would be automatically subscribed since I created it).
Yes! It really is fixed, you're great - thank you for reacting this fast. I love QCad! :)
Marek
