Undo/Redo observation
Panchdara
Post by Panchdara » Fri May 28, 2021 8:58 am
When first started QCAD Edit menu has Undo [-] and Redo [-]
Draw a circle then it changes to "Undo [circle type" -- ("Undo [Center, Radius" being example)
Draw a Rectangle then the Undo menu selection does not change but stays "Undo [Center, Radius".
Likewise for the Redo menu option.
All works as it should, just the type label of Undo/Redo does not seem to get updated.
Never sure if it's a undocumented characteristic, but looks strange to me.
Win 10, QCAD 3.26.2
Windows 10
Re: Undo/Redo observation
Post by andrew » Fri May 28, 2021 10:46 am
Panchdara
Post by Panchdara » Mon May 31, 2021 8:28 am
Thank you.
Windows 10
