Spline line type
lightuser
Spline line type
Post by lightuser » Mon May 24, 2021 4:53 pm
Hi, I recently upgraded an offline machine. QCAD Pro from 3.24.3.0 to 3.26.1.0 and Windows from W10 1909 18363.3.900 to 20H2 19042.985
I have drawings which include control point splines with an ISO dash line type. In the old version the line is continuously dashed. In the new installation the dashes seem to reset at each control point. I''m finding on a spline with control points close together, the dashes never appear and consequently the line appears to be continuous.
I can't find recent posts with this problem so I'm guessing it's new. I'd welcome any help, or confirmation that my issue can be reproduced?
Many thanks, Tim
QCAD Two Splines B.pdf
(9.2 KiB) Downloaded 453 times
QCAD Two Splines A.pdf
(9.17 KiB) Downloaded 400 times
QCAD Two Splines B.dxf
(104.29 KiB) Downloaded 376 times
Re: Spline line type
Post by Husky » Mon May 24, 2021 8:14 pm
Yes - I can reproduce that behavior. Unfortunately I can't figure out why either ... :oops:
Post by andrew » Mon May 24, 2021 8:43 pm
lightuser
Post by lightuser » Wed May 26, 2021 9:29 pm
Thanks Andrew. Is there a way to download the Windows installer for vn 3.24.3 (or the latest version without the bug if you can pin it down)? It would make it easier to continue with my project 'til the bug is fixed. I have access to the shop 'til 5/6/21 but can't spot a list of previous versions. Many thanks, Tim
Post by andrew » Thu May 27, 2021 8:54 am
I'll send you a temporary download link by e-mail tomorrow evening.
