[Solved] Keyboard layout US instead of DE Ubuntu 20.04 Wayland
uwer
Post by uwer » Fri May 14, 2021 8:21 pm
Hi, today I used QCAD 3.25.2 in a Wayland session for the first time.
I noticed that the keyboard layout was US. Could not find a way to switch to my locale DE.
Tried '# dpkg-reconfigure locales' and a reboot. Problem persisted.
Updated to 3.26.2, problem did not go away.
Only in an X11 session does the keyboard behave how I need it to.
Any takers?
From About/System under Wayland (Is identical to X11)
Versions
QCAD version: 3.26.2.0
Date: Apr 13 2021
Qt version: 5.8.0
Compiler version: gcc 4.8.1
Build date: Apr 13 2021
Revision: 57092eac0167e9b1c9b6f012a6024accd6973ea0
Architecture: x86_64
Device pixel ratio: 1
Configuration file: /home/uwer/.config/QCAD/QCAD3.conf
OS: Linux
OS version: 20.04
Locale
QCAD locale: de
Country: 82
Country name: Deutschland
Language: 42
Language name: Deutsch
Script: 7
Script name: Latin
Decimal point: 44
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: UTF-8
uwer
Re: Keyboard layout US instead of DE Ubuntu 20.04 Wayland
Post by uwer » Mon Aug 09, 2021 6:49 pm
Turns out all I needed to do was install the Qt 5.14 version instead of the standard version.
As in
QCAD/CAM 3.26.4 for Linux Qt 5.14 64bit (Installer)
instead of
QCAD/CAM 3.26.4 for Linux 64bit (Installer)
Hope this helps someone.
P.S.: I'm using Wayland because working with large(ish) charts under LibreOffice is painfully slow when using X.
