Objects pasted from clipboard have zero size
Eelie
Post by Eelie » Thu Apr 22, 2021 12:20 pm
I am using version 3.26.2 in Windows 10 (64)
I have suddenly hit a problem with cut with reference and copy with reference. Objects that I cut or copy appear in the clipboard but when they are pasted they have zero size properties. A circle will have zero radius or diameter and a line will have zero length for examaple. This has only happened recently.
Re: Objects pasted from clipboard have zero size
Post by andrew » Thu Apr 22, 2021 12:25 pm
Please check the scale when pasting:
Screenshot 2021-04-22 at 13.24.34.png (21.56 KiB) Viewed 3523 times
A value of "1" means no scaling.
Eelie
Post by Eelie » Thu Apr 22, 2021 11:26 pm
Thank you. Problem solved. I'm guessing that's a new feature because I have never noticed that dialogue box before and I wasn't looking for it.
