Mixing languages in layout names
ouilogique
Post by ouilogique » Mon Apr 12, 2021 8:06 am
When a drawing is created, the first layout is named in English "Layout1".
When subsequent layouts are created, they are named in the user’s language. For example in French "Présentation".
It would be better if all names were either in English or in the user’s language, but not a combination of the two languages.
In my opinion, it would be better if layouts were named in English. This would facilitate collaboration in multilingual teams.
Re: Mixing languages in layout names
Post by andrew » Mon Apr 12, 2021 10:01 am
Note that you can choose the name of the layout when creating a new layout block:
https://qcad.org/doc/qcad/latest/refere ... /AddLayout
You can also rename layouts using Block > Rename Block.
ouilogique
Post by ouilogique » Mon Apr 12, 2021 2:18 pm
Yes, I know that the name can be chosen during or after the creation of the layout. I would just prefer the default naming to be consistent.
