[solved] dwgmapconvert: converted dxf file have different extent
pechnik
Post by pechnik » Mon Apr 05, 2021 3:45 pm
After converting dxf file from custom CRS to 3857(web mercator), transformed dxf file have much more bigger extent then original.
Next, i need to generate tiles, but with such big extent, there will be a lot of extra tiles.
dwgmapconvert -crs-out=EPSG:3857 -crs-in="PROJCS["unknown",GEOGCS["unknown", DATUM["Unknown_based_on_Krassovsky_1942_ellipsoid", SPHEROID["Krassovsky_1942",6378245,298.3], TOWGS84[23.57,-140.95,-79.8,0,0.35,0.79,-0.22]], PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433]], PROJECTION["Transverse_Mercator"], PARAMETER["latitude_of_origin",0], PARAMETER["central_meridian",158.466667], PARAMETER["scale_factor",1], PARAMETER["false_easting",1400000], PARAMETER["false_northing",-5316586.442], UNIT["metre",1]]" -f -o transformed.dxf original.dxf
original dxf
transormed dxf
QCAD Professional 3.25.2.0, Windows 10
Re: dwgmapconvert: converted dxf file have different extent
Post by andrew » Tue Apr 06, 2021 8:58 am
This drawing contains arc entities. For such drawings, segmentation must be used as an arc cannot be transformed reliably without breaking it up into line segments.
Please add the option for segmentation, for example:
-segment-length=1
pechnik
Post by pechnik » Wed Apr 07, 2021 7:24 am
Thanks, now it's perfect.
