GDAL (ogr2ogr) generated DXF line weight problem
bumsik-angelswing
Post by bumsik-angelswing » Fri Apr 02, 2021 10:01 am
Hi, different question for the same original DXF file...
test.dxf
Original DXF file
(290.56 KiB) Downloaded 316 times
We are using your Pro product (qcad-3.26.1-pro-linux-x86_64) on Ubuntu 20.04 LTS.
We made a converted (reprojected) DXF file using ogr2ogr by GDAL:
ogr2ogr -skipfailures -f DXF -s_srs EPSG:5186 -t_srs EPSG:3857 test_ogr2ogr.dxf test.dxf
test_ogr2ogr.dxf
ogr2ogr converted DXF file
(147.12 KiB) Downloaded 320 times
The problem is, that converted lines does not seem to reflect Lineweight properly.
This is the original DXF and I applied 2.11mm Lineweight:
original dxf
Screenshot from 2021-04-02 17-54-12.png (68.09 KiB) Viewed 3481 times
This is the original DXF and I applied 2.11mm Lineweight for the same line (polyline precisely, because ogr2ogr redraws everthing in polylines regardless of the original type)
As you can see, line is still so thin even if 2.11mm applied (but it is a bit thicker than normal lines):
converted dxf
Screenshot from 2021-04-02 17-55-15.png (61.22 KiB) Viewed 3481 times
Is there any configuration that I am missing?
Re: GDAL (ogr2ogr) generated DXF line weight problem
Post by andrew » Tue Apr 06, 2021 7:22 am
Note that the drawing unit of the original file is Millimeter and the converted file is Inch.
Edit > Drawing Preferences > General > Drawing Unit
bumsik-angelswing
Post by bumsik-angelswing » Tue Apr 13, 2021 11:34 pm
That's right! so GDAL somehow changed the property of the DXF file...thanks a lot!
