I've noticed when importing PNG or SVG images into my DXF, they always seem much larger than I anticipate they should be. As a test, I created a 6" by 4" PNG and SVG in Inkscape and imported both into a DXF. It shows the SVG as 45' by 30' and the PNG as 48' by 32'. After messing around I realized if I set the width in the options toolbar while placing the images to 72 (which matches the 72 DPI of the png as I created it in Inkscape. I'm not sure what the native DPI is for the SVG?) they show up as 6" by 4" inside of the QCAD model space. But if I look at the properties of those images, they then have width and height factors of .167 and .133.
I have attached the DXF and the two images. I imported each image type twice. Once at the default size (432 by 288 for the png and 540 by 360 for the svg ) as shown in the options toolbar during import, and a second time with a width of 72 entered in the options toolbar at time of import, with the height scaling down proportionally.
I'm assuming I'm overlooking something obvious as usual but I'm wondering how all of this works in QCAD as far as how it handles the image sizes. What is the relationship between size of the image as Inkscape sees it and how QCAD sees it, and why are the PNG and SVG different from one another?
bitmap/svg image import size
- ryancousins
- Premier Member
- import.dxf
- (104.91 KiB) Downloaded 342 times
- image_svg.svg
- (2.32 KiB) Downloaded 370 times
- image_png.png (6.54 KiB) Viewed 4748 times
Re: bitmap/svg image import size
Let's concentrate on the png first, ok?ryancousins wrote: ↑Wed Mar 31, 2021 2:23 amI've noticed when importing PNG or SVG images into my DXF, they always seem much larger than I anticipate they should be. As a test, I created a 6" by 4" PNG and SVG in Inkscape and imported both into a DXF. It shows the SVG as 45' by 30' and the PNG as 48' by 32'.
The size of a bit map is defined in pixel. If you import (or better link) a png etc.in QCAD it will use the actual Drawing Unit for the size. Your png is 576 px by 384 px. Your Drawing unit is inch. Without any adjustment in the Option Bar your png will be placed with the size of 576 inch by 384 inch. That is equal to 48' by 32'.
If you need to scale it down to 6" by 4" just put the numbers in the Option Bar and QCAD will scale it accordingly.
The svg ...
I can't reproduce this example with the provided files.ryancousins wrote: ↑Wed Mar 31, 2021 2:23 amAfter messing around I realized if I set the width in the options toolbar while placing the images to 72 (which matches the 72 DPI of the png as I created it in Inkscape. I'm not sure what the native DPI is for the SVG?) they show up as 6" by 4" inside of the QCAD model space. But if I look at the properties of those images, they then have width and height factors of .167 and .133.
I don't see a 6" x 4" svg in the drawing. What I see is a 6' by 4'. Howsoever 1 inch should be 96 pixel. What Inkscape is doing or what you did in Inkscape eludes my knowledge.
- ryancousins
- Premier Member
How do you link instead of import? I thought even though it says import, it is actually linking it because you still need the original image file in the same directory with your DXF. I didn't think there was a way to actually import the image so it became part of the DXF file.
So one pixel is equal to one drawing unit. Sounds good.
I think one issue was that I have been using file>import to import both PNG and SVG. When I use this method to import a solid filled SVG, I can't make sense of the size that gets imported. I created a solid filled 96 pixel square in Inkscape and it isn't showing up as one inch in QCAD. Since the SVG shows up as a bitmap rather than geometry using this method, I'm not understanding how the size is determined. I know I can use file>SVG import instead and choose the resolution, but then only the outline geometry is imported, and in this case I want to know how things like logos would be handled where I need the solid fills of the SVG and not just the outline geometry.
Nope - that shouldn't be an issue ...ryancousins wrote: ↑Wed Mar 31, 2021 10:33 pmI think one issue was that I have been using file>import to import both PNG and SVG.
Forget this 96 px = 1 inch. Important for an import is 1 pixel = 1 Drawing Unit.ryancousins wrote: ↑Wed Mar 31, 2021 10:33 pmWhen I use this method to import a solid filled SVG, I can't make sense of the size that gets imported. I created a solid filled 96 pixel square in Inkscape and it isn't showing up as one inch in QCAD.
Remember that we talked about this before .... a 96 pixel svg will be imported as a 96 "Drawing Unit" size. If you work in inch it would be 96 inch in length on one side.
As I mention it before - I don't know what you are doing in Inkscape but keep one fact in mind: Inkscape has the size for the graphic and also a size for the page on what the graphic is placed. Sure - important for you is the graphic size but QCAD sees only the overall (Page) size which could be larger.
I made an example svg. The grafic is 500 by 500. The page is 550 x 550.
Imported in QCAD the unchanged size would be 550 x 550.
I assume to avoid the "import size confusion" you have to bring the page size to the overall graphic size. Inkscape has a command for that ...
If you place both svg side by side in QCAD you can't see a differences. But the one with the same page size is easy to control regarding the size - the other one will confuse you ....
- ryancousins
- Premier Member
Thanks again, Husky.
I always made sure to adjust the page size to match the object size in Inkscape for all of my test images. So, for example, a 96 by 96 pixel square was perfectly snapped to a 96 by 96 pixel canvas/page size.
I know you said bitmaps are 1 pixel per drawing unit,
I will keep messing around. I know that no matter what I can always scale the images down as needed in the properties. I was just thinking it would be more efficient to start with an image that's close to the correct size to begin with. Plus when I don't know exactly how things work I go crazy.
but I didn't know you meant that applied to SVG vector images as well.The size of a bit map is defined in pixel. If you import (or better link) a png etc.in QCAD it will use the actual Drawing Unit for the size.
