Where's the units in my dimensions?
simpsonrr
Post by simpsonrr » Tue Mar 30, 2021 4:34 am
My dimensions are showing with question marks where the ' or " marks would be. Example a 5foot 6 inch dimension looks like 5?-6?
The dimension settings under drawing preferences show format as architectural. Is there someplace else to look to fix this or is it a bug?
Re: Where's the units in my dimensions?
Post by Husky » Tue Mar 30, 2021 5:20 am
The used text font for Dim Label doesn't support those characters. Try another text font like "Standard" and see what happens ...
Post by andrew » Tue Mar 30, 2021 6:22 am
You can change the dimension font under
Edit > Drawing Preferences > Dimension > Dimension Settings > Label Font
If you cannot solve the problem, please:
- indicate your operating system and QCAD version
- attach your drawing file
simpsonrr
Post by simpsonrr » Thu Apr 01, 2021 10:24 pm
Thanks, changing font did the trick. I must have accidently changed the font before, I didn't do it intentionally.
