QCAD Professional Version 3.26.1
macOS Big Sur Version 11.2.3
When I go into Dimension Tools>Tolerance and build my feature control frame, I'm getting a large gap between the diameter value and the maximum material condition symbol and between the datum C identifier and the maximum material condition symbol (See attached file).
Thank you,
Uhly-MN
[Solved] Dimension Tools>Tolerance Problem
- Bug Dim Tol.dxf
- (177.64 KiB) Downloaded 420 times
Re: Dimension Tools>Tolerance Problem
A wild guess ...
... Perhaps because the condition symbol is textual "Fgdtm" and exactly that long!?
It could be by standard, but it seems like a bug or at least ground for a feature request.
These can be reported here:
https://www.ribbonsoft.com/bugtracker/
There you'll need to have or make up an account.
Including a link to this topic is always nice. Linking back too
A wild guess ...
CVH,
Thank you for your feedback. I have created a ribbonsoft.com/bugtracker/ account for future use.
Andrew,
Thank you for reporting this as a bug and fixing the issue. Looking forward to seeing it in an upcoming release.
Uhly-MN
Andrew,
Uhly-MN
