[Solved] Dimension Tools>Tolerance Problem
Uhly-MN
Post by Uhly-MN » Mon Mar 22, 2021 2:17 am
QCAD Professional Version 3.26.1
macOS Big Sur Version 11.2.3
When I go into Dimension Tools>Tolerance and build my feature control frame, I'm getting a large gap between the diameter value and the maximum material condition symbol and between the datum C identifier and the maximum material condition symbol (See attached file).
Thank you,
Uhly-MN
Bug Dim Tol.dxf
(177.64 KiB) Downloaded 418 times
Re: Dimension Tools>Tolerance Problem
Post by CVH » Mon Mar 22, 2021 5:25 am
A wild guess ...
... Perhaps because the condition symbol is textual "Fgdtm" and exactly that long!?
It could be by standard, but it seems like a bug or at least ground for a feature request.
These can be reported here:
https://www.ribbonsoft.com/bugtracker/
There you'll need to have or make up an account.
Including a link to this topic is always nice. Linking back too :wink:
Post by andrew » Mon Mar 22, 2021 9:23 am
Uhly-MN
Post by Uhly-MN » Mon Mar 22, 2021 9:24 pm
CVH,
Thank you for your feedback. I have created a ribbonsoft.com/bugtracker/ account for future use.
Andrew,
Thank you for reporting this as a bug and fixing the issue. Looking forward to seeing it in an upcoming release.
Uhly-MN
