[solved] Not copying a layer
TSG
Re: Not copying a layer
Post by TSG » Mon Mar 22, 2021 10:32 am
Nice job Andrew. That wasn't easy and as often, the problem is in front of the screen.
spectric
Post by spectric » Mon Mar 22, 2021 5:44 pm
Hi
How can you avoid making this mistake again, my interpretation is that an object has been created, the line but not given a value for it's length property and in doing so it causes these issues. Can you explain a little further please as I cannot be the only one who can make this mistake.
thanks Roy
Post by CVH » Mon Mar 22, 2021 6:25 pm
Some methods return Null length entities.
It was the first thing I looked for!
:lol: :lol: :P :D :) :|
Cutting, trimming .... some do, in certain cases, most don't.
Explained as intended behavior. :shock:
It will serve someone somehow. :roll:
Less every few application updates ... :P
If you detect such from a certain method, but consider it as a BUG then filing a detailed bug report is advised.
Menu > Modify > Detection > Detect Null Length Entities (MZ)
There are also methods that might return Null-entities.
These entities, one can't select at all :!:
After file Save/Revert these are located at the origin as zero length entities. :wink:
Fuzzy that all the block entity area (including the zero :wink: ) must be selected.
Only the Block reference point would be enough ....
spectric
Post by spectric » Mon Mar 22, 2021 8:22 pm
Hi
Thanks for that feedback, I have never ventured down that path but having now read that part of the manual it makes sense, a means to cleanup a drawing. I am progressing slowly with Qcad and having great success with being productive but I do realise that there are going to be more efficient ways of doing some of the things I currently do. In the Modify menu it is the copy/move and trim that I use most but I can see others I need to get familiar with.
I will now close this issue and take it as a good lesason learned.
