[Solved] Library Export Dimension Text Issue
ryancousins
Post by ryancousins » Sun Mar 14, 2021 9:38 pm
If I select everything in model space in the "Test File.dxf" and create a new library item from that selection and then open the new DXF that is created ("Text File Library Export.dxf"), the dimension text is not the same color. And I can't figure out where it's being told to be green at all. Any ideas?
Test File.dxf
(112.27 KiB) Downloaded 297 times
Test File Library Export.dxf
(100.35 KiB) Downloaded 294 times
Re: Library Export Dimension Text Issue
Post by Husky » Sun Mar 14, 2021 9:51 pm
... the dimension text is not the same color. And I can't figure out where it's being told to be green at all. Any ideas?
Maybe because the "Drawing Preferences" Dimension settings in that drawing are set to Label color = green?
ryancousins
Post by ryancousins » Mon Mar 15, 2021 3:13 am
Well that's embarrassing. Thanks Husky!
